compro caixa de velocidades para toyota ae 86
carlitos16
boas, procuro caixa de velocidades para ae86.
obrigado
obrigado
carlitos16
carlitos16
carlitos16
carlitos16
carlitos16
andre_costa
The T-50 gearbox was fitted to other engines as well, such as 1S, 2S, 2T, 3T etc. The gearbox itself is visually identical, however the bellhousings differ to suit the parent engine, and the tailshaft housings vary. There are two types of T-50 gearbox - referred to as 20 and 22 spline. This relates to the number of splines on the gearbox output shaft. They both have the same number of splines on the input shaft. There is also a difference in the diameter of the input shaft bearing, which is covered by the bellhousing - 62 mm vs. 68 mm. I ass-u-me the 68 mm bearing is the 22 spline gearbox. The 22 spline gearbox is more desirable as it is apparently stronger. It is also what all AE 86 RWD 4AGEs came with.
This means that the ability to swap a bellhousing is dependent upon getting a bellhousing to match the input bearing diameter. This is particularly important if you wish to upgrade from a (say) 2TG engine to a 4AGE, and intend re-using the gearbox. I suspect some 2TG T-50s are 20 spline and others are 22.
The AE 85/86 series T-50 gearboxes are 650 mm from bellhousing to centre of the gearlever mount, however some tailshaft housings fitted to other cars are shorter, possibly allowing relocation of the gearlever with some mixing and matching of components.
In Australia at least, SOHC 4A engine T-50 bell housings have the clutch mechanism on the LHS, whilst 4AGEs have it on the right. I found a 3A T-50 with a LHS clutch slave cylinder recently. I believe all K-50 bellhousings are RHS clutch mechanism - certainly in New Zealand.
carlitos16
