¿¿Fase2 megasquirt em Fase1 carro??
T_AE86
Mensagem por T_AE86 » 21 nov 2010, 11:54
Oi
Pode-se instalar um Fase2 megasquirt (89661-12130) em un Fase1 (89661-12060 instalado). Haveria problemas? Qual é a diferença? (Fase2 +-1.000€ Fase1 +-500€)
Desculpe meu "Português google tradutor"
Re: ¿¿Fase2 megasquirt em Fase1 carro??
Mensagem por isac » 21 nov 2010, 18:59
When you say Megasquirt you mean OEM ECU. Megasquirt it's another story. [smilie=dirol.gif]
You shouldn't mix ECUS from different years 83-85/85-87, already bought several for dismantling and they have different components and circuit boards.
With patience and luck you may find the correct part number ECU at ebay.co.uk, plenty of them at reasonable selling price (25 to 50 euros) from time to time.
T_AE86
Mensagem por T_AE86 » 21 nov 2010, 19:22
isac Escreveu:When you say Megasquirt you mean OEM ECU. Megasquirt it's another story. [smilie=dirol.gif]
Sorry!! :oops:
Sorry for the prices, haha!, these are that appears in the toyodiy (approximately).
I didn't say before, i have a complete kouki engine, and it was faster than the zenki mine. I changed injectors and intake cam, but something is missing in high RPM (about 6.000 pushing disappears, aldo did it before the change) i think it will set-up, but i thought it would improve something with the ECU.
Thanks!!
Mensagem por MadAE86 » 23 nov 2010, 00:03
Take a look at your TVIS.
Isengard
Mensagem por Isengard » 30 nov 2010, 22:47
Parece que é mesmo um problema frequente :P
