Material vendido movido para o segundo tópico
Preços com portes incluídos, preços negociáveis para compras superiores a 1 peça.
19100-16060 DISTRIBUTOR ASSY €130 (sem problemas)
89456-12010 RESISTOR, VARIABLE €7
85910-30050 RELAY ASSY, CIRCUIT OPENING (FOR EFI) €30
55353-12050-01 BRACKET, SPEAKER MOUNTING, NO.1 / 55473-12031-01 PANEL SUB-ASSY, INSTRUMENT PANEL SPEAKER €20
??, DISC BRAKE, FRONT €25
23280-16020 REGULATOR ASSY, FUEL PRESSURE €15
23270-52011 DAMPER ASSY, FUEL PRESSURE PULSATION €15
25804-16010 VALVE SET, VACUUM CONTROL (tem um pino partido) €10
55558-12060 EXTENSION, INSTRUMENT PANEL €10
81521-12470 LENS, FRONT TURN SIGNAL LAMP, LH €10
11210-16010 / 11212-16010 COVER SUB-ASSY, CYLINDER HEAD €30
11325-16011 COVER SUB-ASSY, TIMING BELT, NO.4 €15
Suporte MANIFOLD, INTAKE €6
69277-14030-01 BEZEL, FRONT DOOR INSIDE HANDLE €10
15607-16021 / 15609-16011 BRACKET SUB-ASSY, OIL FILTER (20v) €15
16331-16100 OUTLET, WATER 20v BT €6
€6
89661-12130 COMPUTER, ENGINE CONTROL €150
85110-12280 MOTOR ASSY, REAR WIPER €30
Air Filter Base Plate Baseplate suits Piper X Pipercross PX600 / ITG JC40 €25
48660-19115 BAR ASSY, STRUT, RH / 48670-19105 BAR ASSY, STRUT, LH €25
13470-16010 PULLEY, CRANKSHAFT €20
13470-16010 PULLEY, CRANKSHAFT €90 (1000km +/-)
Cornetas silvertop €20
23209-16090 INJECTOR ASSY, FUEL €60 (4)
13523-16010 PULLEY, CAMSHAFT TIMING €25 (2)
58280-12120 BOOT, SHIFT & SELECT LEVER, NO.1 / 58281-12030 COVER ASSY, TRANSMISSION, FRONT €25
55472-12050-04 PANEL SUB-ASSY, INSTRUMENT PANEL SPEAKER €15
74220-12060-01 ARMREST ASSY, FRONT, LH €25
55550-12240-04 DOOR ASSY, GLOVE COMPARTMENT €25
55045-12100-04 PANEL SUB-ASSY, INSTRUMENT PANEL FINISH, LOWER €15
48740-12021 ROD ASSY, REAR LATERAL CONTROL €20
48511-19135 ABSORBER, SHOCK FRONT (FOR CARTRIDGE TYPE) €25
48531-80056 ABSORBER ASSY, SHOCK, REAR RH / 48531-80056 ABSORBER ASSY, SHOCK, REAR LH €50
87940-12791 MIRROR ASSY, OUTER REAR VIEW, LH €15 (vidro partido e plástico estalado)
90501-33001 SPRING, COMPRESSION(FOR INNER) €25 (7)
Injectores silvertop 20v €40 (falange vendida, apenas os injectores)
17141-16360 MANIFOLD, EXHAUST 20v BT €40
27060-16350 ALTERNATOR ASSY €100
SHIFT LIGHT (MEGASQUIRT MOD) €7 (novo)
WORKS BELL Rapfix Flipper €30 (novo e compatível com outros Quick Release )
Molas 6KG (atrás) MEGAN/BCRACING/ etc €80
€10
[VENDO] Limpeza da Garagem
Re: [VENDO] Limpeza da Garagem
Material vendido
8x------------------------- Material Vendido -------------------------x8
Knocksense (MEGASQUIRT MOD) VENDIDO
Coil VENDIDO
33530-12460 LEVER ASSY, SHIFT (FOR FLOOR SHIFT) / 33530-12460 LEVER ASSY, SHIFT (FOR FLOOR SHIFT) VENDIDO
28100-16170 STARTER ASSY 20v BT VENDIDO
JimStim v1.5 (MEGASQUIRT STIMULATOR) VENDIDO
12511-16080 BRACKET, ALTERNATOR, NO.1 / 13570-16010 IDLER ASSY, V-RIBBED, NO.1 VENDIDO
WALBRO/SYTEC Fuel Pump Toyota Corolla AE86 1.6 16v 83-87 VENDIDO
17179-16030 GASKET, INTAKE MANIFOLD, NO.2 VENDIDO
90176-06012 NUT, CAP(FOR CYLINDER HEAD COVER) VENDIDO
90210-06008 WASHER, SEAL(FOR CYLINDER HEAD COVER) VENDIDO
23807-16030 PIPE SUB-ASSY, FUEL DELIVERY VENDIDO
89452-12080 SENSOR, THROTTLE POSITION (FOR E.F.I.) (20v)
89421-12020 SENSOR ASSY, VACUUM (FOR E.F.I.) VENDIDO
55472-12051-01 PANEL SUB-ASSY, INSTRUMENT PANEL SPEAKER VENDIDO
11214-16020 GASKET, CYLINDER HEAD COVER, NO.2 VENDIDO
17123-16030 COVER, SURGE TANK / 17129-16030 TANK, INTAKE AIR SURGE VENDIDO
11219-16021 COVER, CYLINDER HEAD, NO.3 VENDIDO
75817-19015 MOULDING, QUARTER WHEEL OPENING, NO.2 RH / 75818-19015 MOULDING, QUARTER WHEEL OPENING, NO.2 LH VENDIDOS
PAGID, DISC BRAKE, FRONT VENDIDO
COVER ASSY, CLUTCH VENDIDO
48603-12010 SUPPORT SUB-ASSY, FRONT SUSPENSION, RH / 48609-12100 SUPPORT SUB-ASSY, FRONT SUSPENSION, LH VENDIDO
QSF22E001 QUAIFE Toyota Corolla AE86 LHD Quaife quick rack & pinion kit 2.5 VENDIDO
13405-19145 FLYWHEEL SUB-ASSY VENDIDO
17101-16010 MANIFOLD, INTAKE / 22210-16031 BODY ASSY, THROTTLE / 23260-19035 INJECTOR ASSY, COLD START FUEL VENDIDO
22203-16010 DASH POT SUB-ASSY(FOR THROTTLE BODY) VENDIDO
Coil VENDIDO
Quero a peça.em.preto.que abre o. capot, tens 2 .
Tenho, a azul é que vai com a peça, preciso de trocar.
isac Escreveu:Tenho, a azul é que vai com a peça, preciso de trocar.
Não precisas trocar nada, só quero a peça que abre o capot se tens a preta fora não faças nada.
A azul é que está solta, tenho que trocar. 30 segundos
up para um bom vendedor! boa comunicação e rápido
obrigado
vaini Escreveu:up para um bom vendedor! boa comunicação e rápido
Utilizadores neste fórum: Nenhum utilizador registado e 151 visitantes
