Boas Malta.
Estou a vender umas trapalhadas que estavam no AE86, quero meter o AE86 de +/- de origem para passar no IPO sem me dar problemas e ficar o meu carro de férias em PT.
Como tenho o black top para o AW11 tenho estas peças paradas a ocupar espaço ja ha algum tempo.
As peças estão em UK (ia montar no AW11, mas depois encontrei o BT a bom preço), mas posso trazer para Lisboa.
se alguém tiver dificuldade com o Inglês que diga que eu traduzo :)
I am selling a few bits and bobs that have been taken out of my AE86.
The car is now running with a standard engine and as a weekend car instead of trackday car as it used to be, so no need fore the following:
• Fidanza Cam gear (one only) £55 ot €67
6061 T6 Billet Aluminium
Stainless Steel adjustment screws and nuts
Outer Gear hard anodized for strength
12 degrees of laser etched adjustment for advance and retard
Bevelled tooth edges help to increase belt life
• HKS Camshaft Exhaust 272 degrees duration and 8.1mm lift £165 or €200
HKS camshafts are not reground OEM units; they are machined from new billet cores which are constructed from a high nickel content iron alloy. By manufacturing all camshafts from billet cores, HKS is able to produce camshafts that equal or exceed the quality of the OEM units they are designed to replace. HKS camshafts are direct replacements and are designed to be compatible with the factory valve train components. However, due to the higher profile of HKS camshafts, HKS high performance valve springs are highly recommended, and required in certain applications.
• TODA Racing Intake Camshaft 288 degrees duration and 8.5mm lift £205 or €250
Toda are the best camshafts that I know of, they are not easy to get hold off anymore
You can see them working (when they were in my car) in here :
http://www.youtube.com/watch?v=pALU9REN4tg
The items are in UK but can be shipped to Europe.
Pics in the next post
PS: se alguém tiver dificuldade com o Inglês que diga que eu traduzo :)
[Vendo] CAMs (TODA 288 8.5mm & HKS 272 8.1mm (4age 16V)
Re: [Vendo] ITBs CAMs e outros (4age 16V)
Quanto pelas meias?
as meias já estão com 50% em cima devido ao fedor e extra ventilação86Pilot Escreveu:Quanto pelas meias?
Que som e andamento é uma pena retirares isso tudo.
Os ITBs já foram vendidos, as CAMS ainda estao para venda ....
Cams com a duraçao e lift ideal para quem quer manter o bloco todo de origem....
Utilizadores neste fórum: Ahrefs [Bot] e 79 visitantes
